The ASIC hardware table utilization has exceeded 90 percent for the above resource. This may cause switch performance degradation.
Resources may be freed by unconfiguring certain features, depending on the affected hardware table. Route compression can be used to reduce Route table usage.
Warning
The utilization of %tableName% hardware table on slot %slot% has exceeded 90%%
| Name | Type |
| tableName | String |
| slot | Slot |
